code 105 on s14 HELP!!!
newpuy
My s14 has engine light on (code 105) I have check the EGR valve already it’s working probably and so the solenoid. But I still don’t know why my s14 still have engine light code 105 comes up please anyone help
sirwarrior
check the absolute pressure sensor
Turn on the ignition and check the voltage between ECM pin 66 and groudn. SHOULD BE MORE THAN 1.74V
(Yeah, I love the ALLDATA!!!!)
newpuy
how can i do that exactly? I don't know much about this car I just bought it last 2 week. All I know is it has ka24de in it and I try to get rid of the enngine light
newpuy
also where is the canister Solenoid valve on s14 (ka24de) ??? I found one but I am not sure because it's doesn't have any electrical connect with it. what I sew was only 3 hoses that connect it ( 2 on the top and 1 on the bottom )
newpuy
I just figure it out. the canister Solenoid valve is very pain in the ... it's all the way in the back of the engine. when you see the egr valve and something similar try to follow the host line and you will fine it. it's almost in the button of the engine and it's vary pain ... to take it out. first you have to take the metal out first then you can change the canister solenoid valve out side. but be careful dont burn yourself wait until engine is cold then work on your car. also be careful when you take the harness out you have to disconect I think like 2 of the harness """ be careful the the clip you have to use screw driver to remove the clip first then you can lose the harness otherthing try not to let the clip slip off it's easily spring out... and good luck guy
