Defiant »
https://forums.nicoclub.com/defiant-u43224.html
Sun Jan 07, 2007 4:54 pm
The Teflon won't help. Oil isn't "heavy" and it doesn't "stick" to parts in that way. You may have a thin layer which coats parts, but once that's on there, it won't care if it's coating raw iron or Teflon, and you're still back at the oil flowing off the oil coating. So you have viscosity to deal with- which, in a running engine at temperature, isn't an issue.I don't know about the oiling problem, if it is one. Ask the fellows who are posting about it.
