CMS performance 240SX S14 VQ SWAP
evoprime1
Car: 95 240sx s14
motoman399
Car: 98' wrecked (RHD coming soon) 240
lol little tig welding.
Dittoz7
Car: 1997 2f0WtY SE!
Hood clearance.
evoprime1
Car: 95 240sx s14
hood will clear.
Dittoz7
Stock hood?
motoman399
i love at :35 "header on this side for clearancing purposes he tig welded it a little bit there"
there is no way that a stock hood will clear that. nope
Dittoz7
Either way nice progress keep us updated.
Origin Type II *might* clear it.
evoprime1
Car: 95 240sx s14
motoman399 wrote:i love at :35 "header on this side for clearancing purposes he tig welded it a little bit there"
i think we got it... that you love the tig weling phrase..
well i was gonna wait till vehicle is back from paint and body to post up a new video of it w/ the NONE!! stock hood on it.
so you guys could check it out but since we are on that topic i'd like to let you know that NO!! the stock hood wont clear and YES!! it dose have an aftermarket hood on it. this was just the intial 1st vid. but none the less enjoy... it was a def a dope and fun swap to do
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
seems like your goal should be worded different if a stock hood won't close over it.
"OUR GOAL:
-to make this car run as if this motor belongs in it ********* JOB COMPLETED GOALS HAVE BEEN MET*********"
It looks like it sits higher than it should. But I bet its fun regardless. I want a VQ swap but they are a b**** to wire.
motoman399
evoprime1 wrote: i think we got it... that you love the tig weling phrase..
and it has one header!!! LOVE
cool swap though. props for doing a clean job
venom90s
Car: 91 240sx
70 ford maverick
i'm guessing you had to make custom ac lines and power steering lines too right?
evoprime1
Car: 95 240sx s14
breadbox wrote:seems like your goal should be worded different if a stock hood won't close over it.
"OUR GOAL:
"to make this car .......RUN........as if this motor belongs in it"
i ment engine wise (run) nothing to do w/ the fittment of the hood :bigthumb:
the significance that this car holds:
-to make a package deal availible for ppl that would like to do this swap.
- have all the stock gauges work w/ the VQ engine speedo/rpm/water/fuel
and have a functioning OBD2 port to pull codes (witch it does) as you can tell in the vid no need for AEM or any other stanalone unit just plug in and go...
-so you can install one as easy as possible, including a PLUG AND PLAY wiring harness and custom made mounts that position the engine so you dont have to cut grind or do any fabbing. this engine dropped right in with out doing any of that.
more of this will be covered in our next vid when car is back from paint.
MOTOMAN:
this car is a V6 dude it has 2 headers one on each side this is a VQ35de out of a 07 infinity
it says V6 on the engine cover :bigthumb:
yes custome AC and power streeing line were made... car blows cold as ICE AC and has great power steering not hard at all to do very simple :bigthumb:
motoman399
evoprime1 wrote:
MOTOMAN:
fully aware that its a v6 and requires 2 exhaust manifolds (headers). the dude in the vid said header, thats where the joke was. i was jut yankin your chain. dont take offense to it. like i said though good job on the clean swap. i was actually thinking about doing this swap in my car. i know a guy that wants me to put a 2jz in his 350 and i was pondering the idea of using his engine.
evoprime1
Car: 95 240sx s14
motoman399 wrote:
evoprime1 wrote:
MOTOMAN:
thats because only that side needed to be worked on the other side fit just fine. as stated.. HEADER(x1) on that side needed a bit of tig welding for clearence.
no offense dude just trying to correct any miscommunication :bigthumb:
anyways thank you for your compliment on the clean install we had the engine bay painted befor we put the swap in it so that way the engine bay would look nice with the engine in it. i test drove the car and loved it :dblthumb:
if you have the chance to do it..i say go for it... very dope!
breadbox
89 Koop
84 720 4x4KC
Sweet. I keep hearing you either have to wire it up a 95 maxima ECU, Other ECU's but with a piggy back and flash to disable the Safety crap, or Standalone.
If you made it Plug and play, I'd attempt a VQ. So far haven't seen anything close to that yet.
