ClutchMasters Stage 5 clutch..Do you get chatter?
uncle_louie83
Car: 1993 Nissan 240sx Coupe
well....ive had the CM stage 5 clutch for oh prolly about 600 miles est. And i noticed im getting a little chatter at idle...not much....but i was wondering if anyone else got chatter from the clutch masters stage 5 kit. This is the full race 4 puck unsprung hub ceramic pad disk also. Hehe...ive already busted 1 trans...shreaded 1st gear with a 7k rpm dump with this clutch. Ive heard of other people having chatter with full race kits like mine so thats why im asking...
lewis
p.s. the disk you see in my avatar is the disk i have in the car
uncle_louie83
well i guess no one owns this clutch but me....anywho....if anyone reads this....chime in
Aries
Car: LT1 240SS
we had a custome car do this. Called clutchmasters and they said it is a common problem with the stage 5.
uncle_louie83
thank you for your reply....
Structure240sx
i dont notice any chatter at all with mine, although it should being 4puck unsprung
tiger
super singles chatter when the clutch pedal isn't depressed. sounds like something's vibrating against metal, completely normal.
koukiKA240
Car: 1991 240sx KA-T
yea i have sound similar to that, i have this same exact clutch. Another problem i have is at 3krpms it rattles and at autox when im comming down from the 6k rpm range in gear it rattles all the way down to 3k and stops. But i think thats my pilot bearing.~Sam
hek1620
Car: '89 240sx
damn how much power does it take to shred gears?
InsanityInc
hek1620 wrote:damn how much power does it take to shred gears?
It's not so much a question of power so much as it is a question of accelerative rate causing more force. If your transmission isn't moving, and then you rev to 7000 and dump the clutch and the clutch doesn't slip at all, your driveline is going to accelerate VERY quickly, and F = MA.
Maverick7687
Car: Sagemist(FSO) 1998 Maxima SE & Charcoal Metallic(KG2) 1993 240sx & My newly aquired Pearl White 1990
InsanityInc wrote:If your transmission isn't moving, and then you rev to 7000 and dump the clutch and the clutch doesn't slip at all, your driveline is going to accelerate VERY quickly, and F = MA.
and that = a SMMOOTTTHHH 1st gear
Mav
