Equinox wrote:What'd did you do to break in your clutch? I keep getting different opinions. Someone told me to just drive it like normal, others say keep it under 4000rpms but vary it, and still someone else said to just do a couple of burn outs!?!
I took it easy and kept out of the boost. Basically what you want to avoid is making the clutch hold onto a lot of torque. Take your time when you shift. By that I mean when it comes time to shift, hold in the clutch for a second or two, grab the next gear, let the clutch back out. Don't be super paranoid about it, but do take an extra second or two with each shift.
Basically, forget that you have a turbo and deal with being the slowest person the road for about 1000 miles. Once you're at 700+ miles or so, go ahead and take it up to the higher RPMs (4000-5000) and then let the car slow down. That will get the clutch used to "holding" the torque without having to "grab" it.
Once you're over 1000 miles, try some high RPM shifts and see if it holds. It should.
Whatever you do, don't burn out. Save that until after you've broken it in.
edit: I just saw that you have an organic disk. How does that differ from kevlar? Mine is kevlar, so it has some wierd characteristics, and behaves differently whether it's cold or hot.
