corn322 wrote:you don't need to turn the car off and back on.
The only time you need to shut off the car is when you stop. Every time you stop. Stop signs, stop lights, etc.
When you come to a stop light, put the car in neutral, stop, shut it off, put it in 1st (it'll be tough to get in 1st with out the clutch), then start the car in gear while using the throttle. The car will want to jump and you might peel out a bit, but it's the only way to do it. Other than just blowing through red lights. Oh, and don't stop uphill.
