Clutches????
azrps13
Car: My Car
Hi guys...
My problem is that i dont know where to buy clutches or what type of clutches are availible for the RWD CA... Can I use a KA clutch? or do i have to get a clutch for the CA18Det?
Nismo1182
Car: Z06
Spec now makes CA clutches and you can use a KADE clutch with minor modification to the flywheel.
azrps13
Car: My Car
What kind of minor mods?
Nismo1182
Car: Z06
drilling out one of the pins on the flywheel.
azrps13
Car: My Car
Are CA clutches and KA clutches about the same prices?
NeedCAforS13
Car: CA swapped S13 coupe
yes... and you don't have to drill the flywheel, just use some vice grips and pull one of the pins out:) works better than drilling!
Sean
USDM_OneVia
Car: Racing
Some one buy my Spec Stage 1 clutch!!! Brand new in the box!
Joe
NeedCAforS13
how much joe?:)
Sean
USDM_OneVia
Car: Racing
275 to your door! I got it the same day that I already had the motor half-in and I wasn't about to repull it, put the clutch on, and then redrop it. So the clutch has been sitting on the work bench in the garage unopened since then.
Like I said brand-freakin-new, tape still on box!!! I need to move this and get more go fast stuff and light up my stock clutch first!
Joe
