JRL »
https://forums.nicoclub.com/jrl-u26048.html
Thu May 19, 2005 5:23 pm
Theres a forum member that is having good luck at 12 lbs (T3) using a SOHC Hardbody clutch, flywheel, and pressure plate. Its 20mm wider than the stock DOHC clutch/flywheel.
If you think about it, trucks were made to tow/pull. So it make sense that it would be stronger. Plus, its the same clutch as the 280Z, so the upgrades are there if you need them.
It fits with some slight cutting, and grinding (no welding though).
