Clutch wont retract without help
snowyred180
Car: 1994 Nissan 300zx TT, 1995 Acura Integra GS-R, 1994 Honda Prelude
Jut go a 1991 240sx shell. Dropped in the motor and transmission from a 1993 240sx. Clutch, flywheel, and slave cylinders are new. The transmission goes in gear and the slave cylinder actuates, just the clutch goes straight to the floor and wont come up by iteself. System was bled and fluid is coming out of the lines. It has sat for a while though and the fluid was dirty. Maybe the master cylinder is bad? It's not leaking anything.
I've searched so long my eyes are about to pop of of their sockets. Any ideas?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I would try bleeding it to see if that help, but it could be a clogged clutch line, bad slave, or a bad master.
snowyred180
We tried bleeding it for a while today. Slave cylinder is new. Maybe it is a clogged line or master.... that fluid was nasty. I'm trying to think of anything else that would cause this.
240ChukiSX
Car: 1992 Nissan 240sx Hatchback, 2.4L KA24DE
Same stuff to my car. I replaced the whole clutch and flywheel, plus a new slave cylinder and it won't retract back up without me pullin it back. Tomorrow I'm replacing the clutch master cylinder. I'm going to let you know what happens. Your problem is exactly the same as mine. If it works, I'm going to let you know.
SkinnyKibbles
Car: 1990 240sx
It has to be your master cylinder, same thing happened to me.
Wretched
Car: 93' Hatch
Clogged line and you won't be able to press the pedal at all. Sonde like you still have a big air pocket or a bad clutch master cylinder.
snowyred180
I was kinda thinking the same thing too... I'd be really pissed if I had to take the transmission out again because of something dumb. I have a spare master cylinder from the car I took the manual transmission out of. Hopefully that one will be ok. And yes, let me know how the master cylinder replacement goes! I greatly appreicate the input, guys.
This car has been sitting for like 2 years. The fluid was so nasty it was almost black. It wouldn't surprise me if I found buried treasure in there or something.
Unrelated, but the good news is I have two working headlights now though! Turn signal switch= fail.
uraznfriend
did you remove the clutch dampercuz i had that same problem and bleed the clutch for hour and got nowherethen i remove the clutch damper and after a bleed it worked fine
snowyred180
Didn't try the damper. I'm going to try the master cylinder first. If that doesn't do it, that damper is just coming out. I found a nice write-up on how to bypass it!
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Rip the damper off.
snowyred180
haha I'm gonna
SR24DET
Car: RMS13
Dont waste your time with anything but the dampener. I garentee you that is it. Just connect the master straight to the slave.
snowyred180
It looks like a lot of people have done the bypass... does this thing malfunction a lot?
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
the junk dampener goes out. your car is almost 20 years old. mine is a 93, and doesn't bleed all the way. I have mushy pedal feeling after doing a clutch job. my car is in storage because I don't drive it in winter. I still have yet to remove the dampener. I really wish they sell a bypass line instead of bending the hardline.
just wondering if this happens to anyone, my clutch works fine when its cold. after 7 miles, it starts to act up a lot on me. when I press the clutch all the way, I get this whirring sound on my transmission but goes away after pumping my clutch pedal like 5 times. just a thought if anyone has the same problem as mine.I am not really worried since I will be swapping out the motor eventually. hate to throw away a nice KA that only has 109K since it runs really strong and no issue.
asoomal
nifares240 wrote: I really wish they sell a bypass line instead of bending the hardline.
http://www.frsport.com/DIF-100....html
nifares240
thanks, but that's a conversion line from clutch master to slave.
ocalas240
conversion line is the same thing, pretty much. why would u wanna keep the hardlines? might as well just run a SS braided line. it makes sense to me, and enjuku has them for $35! thats what im doing soon here.
not trying to thread jack...
OP-
I did the damper thing, and it helped but it didnt fix it.Then i replaced the master cylinder and flushed the whole system with fresh fluid. Worked better.Then adjusted my clutch pedal and BAM!! it works amazing!!
so incase nobody understood my rambling....
Remove DamperReplace Master CylinderFlush SystemAdjust Pedal
Good luck man!
SkinnyKibbles
Car: 1990 240sx
Removing the dampener was the best thing I've done to my car. You get a much stiffer pedal (if you like that).
SR24DET
Car: RMS13
zer...ystem
Wrote this last night
240ChukiSX
Alright. So basically I replaced the clutch master cylinder then the mechanic said that it was clogged. I was like WTF? It's like one thing after another. Last time I saw my car earlier today, he was taking out the slave cylinder to clean it and see if it was dirty. That's the last time I saw my car. Dunno what is next. I know that my baby wants to come back home to me and get ready to run d streets. Everybody with a 240, feels my pain. PRAY 4 ME!
snowyred180
Removed the damper today. And then my hardline broke. Meh. To be continued...
Master Cyinder had to be taken out to bench bleed since all the fluid came out.
SR24DET
Car: RMS13
2 options.1- buy a ss line2- go to local hardware store and buy another hardline for super cheap. Rebend it the way you want.
when I removed my dampener, i broke mine too. I went to autozone and got another hard line for $3. I spend another $10 and got a little pipe bender. I rebent the line and installed. Done.
snowyred180
Yeah my dad has a fluting tool for the lines. I got the same end pieces but they feel a little loose. I have another broken line I might snag the endpiece off of and reflute.
Either that or there's a manual one at pull-a-part. They'll probably charge like $2 for it.
Ah, The joys of having a full 5 spd swap before you buy a manual shell...
k00laid83
i would just pick up a steal braded line and a couple of fittings and bam your done! no worries about breaking the like and what not. thats what i ended up doing with my car and the clutch feels soft as hell.
snowyred180
Removed damper, clutch fixed! Thanks guys!
