cmurder342 »
https://forums.nicoclub.com/cmurder342-u88130.html
Fri Jan 08, 2010 3:55 pm
Hey guys I got a problem and ive been researching my brain off and working my butt off in this horrible snow storm for the past week and half doing an auto to 5 speed swap on my 1990 240sx and ive ran into multiple problems first it was i got everything out and swapped with my 5 speed transmission and that in and found out that a dude sold me a f**ked transmission that was busted off in reverse so I had to drain and pull everything back out...(PITA) but did that and luckily i thought smart and had bought another transmission for a cheap price for a friend and got new throwout bearing, master cylinder and slave cylinder for it so i put all that together and put that transmission in which is guarenteed to be good and i bolted it all back up checked fluids, filled transmission back up, checked all wires, adjusted clutch pedal by the lock nut and rod where it needs to be. so i fired her up and she purred like a kitten but one problem.. it will shift through gears while off but when on its a no go... i tried multiple times and everything and its just like the clutch wont engage but i know its trying because when i try and put it into first the car will pull forward like 3 inches then stop. also my clutch pedal is very very very loose like a baby could push that b*tch down and i read multiple forums (including nico) and sites and they all say "bleed the clutch, and adjust clutch pedal or get new master or slave cylinder" well theres the thing ive done all of that and still no clutch engaging at all so please dear god if anyone can help me please do i really need this car as my daily driver and i have to leave for college in like 2 days which is 60 miles away from my house and i just need this to happen and ive been through hell workin on this thing for the past week and half, so please anyone have any similar problems or know the solution of the problem, PLEASE let me know thanks
-Clint
Modified by cmurder342 at 4:20 PM 1/9/2010
