POS_S13 »
https://forums.nicoclub.com/pos-s13-u10737.html
Tue Jul 13, 2004 9:45 am
i did replace the master cylinder...
well i bled the hell out of it the other nite. figured maybe it just needs to be all worked in. so i started it in 1st, car started moving forward so i just applied some gas and started going. with some force i was able to get thru all the gears up to 4th, didn't have enough straights to get enough speed to shift into 5th.
so i come up to a stop sign, found out i need to rev match perfectly to downshift. ready to downshift from 2nd to 1st and it wouldn't go into 1st. so i let the rpms come down and idle, still won't go into 1st. so i turned the car off, put in 1st, start it up and pull back in the drive way. clutch feels perfect (presure-wise), no leaks from the master or slave. now its really bothering my cuz i have no clue what the problem is, guess this weekend its time to take apart the transmission and find out whats goin on in there.
