den240 »
https://forums.nicoclub.com/den240-u14795.html
Tue Feb 08, 2005 10:20 am
Got a cool new problem I've not encountered before:
My clutch has decided that it will no longer disengage.
For a while it worked correctly when the engine/trans was completely warmed up, now it won't disengage at all. This made me think it was a hydraulic problem, so I replaced the slave cylinder , then the master , then replaced the extra connection that is where some cars have the damper loop with a shorty solid pipe connection . Then bled and bled and bled the system . still not disengaging!
The slave cylinder end of the actuator arm moves approx 5/8 inches, which seems like a reasonable amount, so seemingly the hydraulics are working OK.
I also replaced the release bearing as it was squealing and needed replacing anyway, but didn't do anything with the pressure plate and disc. (they have only been in for about 8k miles, and they are what I thought was good quality ACT parts...)
All the other possible problems I can think of at this point are:1. actuator arm is bent so is not moving the release bearing far enough?
2. the pivot point that holds the actuator arm is not holding correctly? (seems OK when I tried moving the arm when no slave cylinder attached)
3. pressure plate fingers somehow got bent or something similar so they don't push far enough?
Anyone want to push me some guesses of what I should look at first of these three or any other guesses of what the prob could be?
den240
