clutch won't disengage. how much $ am i looking at?
Yorb
Car: 1992 Nissan 240SX SE Fastback
welp, i was driving back from nissandrift's place with my new MAFS (which didnt totally fix my bogging problem... but i think its better). as I merge onto I-40, i figure i'll redline it to get everything running smoothly and make sure the car is functioning. stupid idea.
4 hours later, here i am, my cars at the shop again courtesy of AAA, and i have to get up at goddamn 7am to take my mechanic the keys.
so, what do you think is the matter? basically after 2nd gear the clutch stopped disengaging. car barely moves, and that's at high revs. didn't do that needless to say for fear of burning the clutch out. mechanic didn't seem to think it was more than just a slave cylinder (whatever that is), and it would be easy to fix. he didnt seem as confident about how much it would cost though.
anyway. =( theres my bummer story for the day.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
you'd be lucky if it was the slave, cuz that would be easiest and cheapest to fix.
rico05
Car: 1992 RMS13 w/ CA18DET
Pedal come up from the floor? If no, it is just your slave. If not, pp may be blown.
Yorb
yeah the pedal comes up fine. it actually moves smoother than it ever has before. =/ its just that theres little difference between when its down and when its up. whats this about my pp?
fuzion
Car: Cars.. Web/graphic design.. Yuppp
PP = Pressure Plate I assume
It holds the clutch against the flywheel (right? k...)
I've replaced my slave cylinder twice.. (just replaced it about a week ago); I spent $17 for a new slave cylinder + $4 for a large bottle of brake fluid.. it's cheap..
Nvkreationz
Car: Cars
i would suggest to get a whole new clutch set..becuase this happen to me b4 or unless your car was running too long
Yorb
why would i pay for a whole new clutch set if it only turns out to be one part? =/ i am sadly not mr. moneybags
SeVa-S13
Car: '05 GTO 6spd
I speak from recent experience: The only place I could find that sold the Pressure Plate separately was a Nissan dealer (~$100).For that same amount of money, you can get an entire clutch kit from your local parts store; clutch plate, pressure plate, throwout bearing and an alignment tool to boot.
Yorb
hey, guess what. we were all wrong. i destroyed the entire clutch. $500.
fuxor me in the goat azz, that makes about $1700 of repairs into this 240 in the past WEEK.
