Patarach »
https://forums.nicoclub.com/patarach-u72864.html
Thu Dec 03, 2009 6:25 pm
Hi everybody I recently did a clutch swap and j30 vlsd swap on my 93 ka24det, I got everything back together and now my clutch will not disengage,
Master cylinder and slave cylinder- Both operate smoothly, but I'm not positive if one of them isnt working 100% . I'm going to double check this tomorrow, but I doubt its the problem.
The clutch feels normal on extension and retraction of the clutch pedal.
this morning I got underneath the car and removed the dust cover for the pivot fork and watched the operation of the clutch while someone pressed the pedal and from what I can see it is compressing the pressure plate and retracting. to what appears to be normal, I cannot see the whole operation though.
I am using a f1 flywheel that i have used before and not had problems with, i opted to not have it resurfaced professionally as it has not been used long, but I did go over it will fine emery cloth as suggested in the FSM.
My clutch is a centerforce dual friction, brand new right out of the box.
If anyone has any advice before I start to tear the thing down again I would appreciate it very much. thanks
Modified by Patarach at 9:47 PM 12/3/2009
Modified by Patarach at 10:35 PM 12/3/2009
