Clutch will not disengage
unwed_transient
i just completed my 5 speed swap and i cant get the clutch to disengage. i checked the fork it is ok,bled the system many times, it looks like the slave cant travel far enough to disengage. Any ideas?
pmkls2
Car: 1990 240SX Fastback
Sounds like there is still air in the system. Did you install the damper that goes inline from the master to the slave cylinder ? If so toss it because it is crap anyways and s also probably where the air is trapped. Also, it could be that either the master or slave cylinder are just plain bad. Were all these components taken from a donor car or purchased new ? If the hydraulic components are from a donor car then they may very well just be bad. Those are the first places I would look though..........
