Clatch »
https://forums.nicoclub.com/clatch-u17761.html
Wed Sep 22, 2004 4:32 pm
Ok now that everything is fine the problem started over again, I found out I needed to bleed the clutch master and slave cylinders and reapply the brake fluid. So I had a professional mechanic do that and when I got the car back the friction point is almost impossible to drive. It’s at the very top of the throw; I mean the instant you step on the clutch. Before it was nice and comfortable down low. For example...
(FLOOR BOARD)-----------------------------------------------------(TOP Of PEDAL)Before --------(FRICTION POINT)----------------------------------------------After -----------------------------------------------------(FRICTION POINT)
Is this right? The mechanic told me that it was, is he right? Are your cars like this?
