Clutch/ Transmission Problem.. Need some help
Silvia_Ks_90
Car: 1990 Silvia K's w/2JZ
2007 Subaru Legacy Spec. B Stage 2
Hey guys, having a few issues with the clutch, it's not engaging at all. I've bled the system twice now, each time before starting the car up, with clutch in I'm able to easily shift through the gears without any sticking. As soon as i run the car it won't go into anything, it's like the clutch needs to go another couple centimeters for it to disengage. Its on an R154 transmission, with an OS Giken Triple Clutch, OS Push Pull Converter, -3 braided lines, New OeM master and slave. Any thoughts?
S13_RB25
Car: A 240 but no RB yet!
Well since you have a s13. Did you remove the damper box underneath the car??
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
My humble suggestion is to check the clutch pedal adjustment.
The shaft of the master cyl is threaded, you adjust the pedal engagement height by loosening the 12mm lock nut, then by rotating the shaft clockwise (to push the slave cyl more) or counter-clockwise (to push the slave cyl less).
Try small changes first - I suggest 1/4 turn and then test.
