Clutch Tranny- Release Bearing
Allu
Hi
I have a ticking coming from what sounded like under the hood.I took to a local garage and they told me that my release bearing is what is making the ticking noise. They told me it would be cheaper for me to buy a used transmission and put that in, instead of correcting the problem with my transmission. Then i got a little curious and did alittle research and found out that the release bearing is a part of my clutch and not the transmission as a whole. So does anyone know what would be the better option for me?I drive a 1889 240sx sohc.
Thanx Allu
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
Just replacethe release bearing, its a $20 part that should take about 2 hours to install. They go out about the same rate as clutches do, and most clutch kits include them...
Allu
So i instead of just replacing the bearing alone, I should do a whole clutch kit seeing that im going to be under there and just do it all in one shot.Thanx alot Ive Been BadAllu
IveBeenBad
Allu wrote:So i instead of just replacing the bearing alone, I should do a whole clutch kit seeing that im going to be under there and just do it all in one shot.Thanx alot Ive Been BadAllu
No problem. BTW, if you have an Advance Auto nearby, I believe they sell replacement clutch kits with Clutch Disc, Release bearing, pilot bushing, and pressure plate for $100+tax
Allu
Thanks Again IveBeenBadYeah i live in Canada and there is no advanced auto.Ill just order off ebay they have some sweet lookin clutch kits on there.allu
