i have a 1996 Maxima SE 5-speed and am experiencing some problems with my clutch/transmission, nbot sure which tho.
i know for a fact that my clutch is not in great shape. its the key value clutch and i am having it replaced in a couple weeks. my first problem is that i some times experience slight difficulty when trying to shift into 1st or reverse. sometimes it goes in fine, other times, i have to let the clutch out slightly to get it to slide in. these are problems with teh clutch right?
my second problem is that lately i have noticed that it is fairly easy to pull the shifter out of first gear when the clutch is still engaged. i dont mean that with a slight tap it pops out, but if i excerpt a little bit of force on it, the shifter will slide out of first without the use of the clutch. my questions abotu this is;
1. is this a problem with the worn out clutch or the transmision?2. if this is a problem with the transmission, can it be easily fixed when i am having my clutch replaced?
thanks for the help.
