SilFortyTypeX »
https://forums.nicoclub.com/silfortytypex-u6963.html
Fri May 02, 2003 6:36 pm
Hi, I own a 90 240SX and I am having a problem with the clutch/transmission. Whenever I shift into 2nd gear, I get a grinding noise like the sound u get when u try shifting into a different gear without pressing in the clutch all the way. Although I press in the clutch all the way, I still get the grinding noise. Although, if I take 1st gear to no further than 3000rpm, pop it into Neutral, then into 2nd after a whole second gap, I get little to no grinding noise at all. I do not get this noise when shifting to any of the other gears though. So I was wondering what this problem sounds like, and how I would go about fixing this.:help
