Clutch/transmission noise problem?
blackiceee
Car: 1992 nissan 240sx
i just recently replaced my clutch... and now it makes a rattle/chattering sound in neutral. when i press the clutch pedal in the noise goes away. Does the problem have to do with my clutch or my transmission. Someone told me that the throw out bearing might be bad ...but it was replaced with the clutch. if the throw out bearing is the problem ...could it be faulty. The car never made this noise with the old clutch, problem occured once new clutch was put in. need some advice plz.
x240xdrifter
Car: 1991 Nissan 240sx
its your pilot bearing and/or throwout bearing. Its quite common for theses to go, a good rule of thumb is to replace both when your replacing your clutch,
cattrikk
Car: 1989 Nissan 240SX Coupe
did anybody ever think to re-surface/turn the flywheel....its a common forget when people change the clutch...
