clutch toasted after 7000km?
LakaiOrDie
Car: 1991 240sx w/ca18det (n time for a rebuild )
Could this happen already?. act Street disc done two months ago and now it's engaging at the top of pedal travel always and the grab feels short at the feeling of it
still chirps the tires goin hard into second tho
PapaSmurf2k3
Site Admin
I'd say just adjust your pedal first.
LakaiOrDie
thing about that is when the clutch pushrod is threaded all the way into the firewall I can use it but it has o free play N backing it off will make the softest pedal In a few turns and I can't fully disengage
PapaSmurf2k3
Site Admin
Sounds like you're talking about adjusting the master pushrod/fork thing.
I'm talking about the pedal itself. There should be a bolt with a jam nut on it that sets the pedal height/free play adjustment.
PapaSmurf2k3
Site Admin
Or if you have cruise control, there will be a sensor there that you thread in and out.
Here's no cruise:
Here's Cruise:
LakaiOrDie
ah ok yeah I was referring to the master cylinder rod...
the one your describing is in my ashtray lol its prolly my master cylinder failing aye? 3 adjusting bleeding and everything goes swell and I have a free play as it should
then one push to the floor and the whole thing goes limp with no chance of disengagement unless that bolt is removed and the pushrod is threaded in fully
does this make sense let me know if that wasn't a good enough explanation of what's going on
PapaSmurf2k3
Site Admin
Yeah it sounds like a clutch hydraulics problem, not with the actual clutch itself. That means you can fix it without having to pull the transmission! Wohoo!!
Its probably a safe bet to just replace the master and slave, along with getting rid of the damper loop/box.
