Clutch
Sr20_44
Car: Nissan 240sx Sr20det
I have a stage 3 clutch and noticed it doesn't activate until i pretty much let all the way out on the peddle. It also slips quiet a bit? It didn't do this when I first got the car so I don't really understand. It has fluid. Any suggestions?
PapaSmurf2k3
Site Admin
Have you adjusted the clutch pedal free height? You might be keeping pressure on the clutch when you shouldn't be.
Sr20_44
How do you do that?
PapaSmurf2k3
Site Admin
Sort of covered here:
http://www.nicoclub.com/archives/how-to ... -370z.html
Basically you go under there and adjust the stop bolt on your clutch pedal bracket. That should give you the free height. You can then lower the clutch pedal from there via the master cyl rod (if you so desire), and adjust the free height as necessary.
