Clutch
sfrederick
Car: 1995 Nissan Skyline GTS-T
From reading those forums i have understood that the Z32 N/A Clutch fits the RB25DET Engine. The previous owner installed a rb25det f1 clutch from ebay. Upon removing the engine i found the clutch had been destroyed. I then ordered an N/A Z32 Clutch disc and it is slightly bigger than the f1 pressure plate. do i have to buy the pressure plate as well?
Can you please shed some light on this.
mixeds14
Car: 240
when they replace the clutch, it more than likely came with a pressure plate as well, explaining y the z32 clutch is bigger than the pressure plate... keep in mine that the z32 clutch will work on the rb but it will slip on the long run cause it wont be able to handle any kind of abuse.. u really be better of buying a spec or similar clutch kit n save u the work of taking everything back off once the z32 clutch takes a dump on u. they really aint that expensive like 300+ n they are woth it..
try ricky at rawbrokerage.com thats were u can find what u need..i believe hes also a nico sponsor aswell.
sfrederick
So If I get a Z32 Pressure Plate I should Be good to go?
