KaDrifter »
https://forums.nicoclub.com/kadrifter-u8587.html
Sun Feb 08, 2004 4:48 pm
Alright I'm in the middle of installing a ACT 6-puck un-sprung hub and a Findaza 11lb flywheel. Now the problem i have everything bolted up and i can't get the trans to slide in all the way. On the clutch disc it has a flat side and a side that has a collar on it that sticks out i have this on the pressure plate side is this right it is the only thing i can think of that may not be right if it is i guess i will have to play with it some morethanks
