themeanest240 wrote:master and slave are fine,i get in the car not running, push down the clutch, when i go to releas it, it feels weak and doesnt come all the way up with my foot.turn car on, put in gear, release the clutch and it grabs as soon as i lift the pedal.???how should i check the master and slave?
I think it's your slave, but yeah, try bleeding the system first. If you still have the stock dampener box, it will be a PITA to bleed. If you've removed it, then it takes very little time to bleed. Pull the boot aside on the slave, if you see fluid leaking past the seal, it's bad. OEM Slave is only ~$45.
