Ca_laurier wrote:for gaskets all ca18de **** works
for clutchs what are you looking for??
os giken has a killer one and cusco has that clutch
stay away from spec. i hated mine slipped once it warmed up
Stay away from spec? Thats weird I"ve heard a ton of good things about spec, and I know an sr20 200sx with a stg2 plus clutch that works magnificently...... Did you resurface your flywheel? Did you TOUCh the clutch or get anything on it before installing it? The material is ORGANIC, it has to be spot free when you install it.
