clutch
donmada
Car: 91 240sx with a s13 black top sr20det
when clutch is pushed in it drops to the floor and i have to pull it back up no compression in the clutch
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Try bleeding it..Or you might need to replace the master clyinder
90SRpwrd240
Car: 1990 240sx SR20DET
Just happened to me two days ago....It was my slave cylinder on the clutch...I would try bleeding the system first, then I would change the slave cylinder. Very simple, on the passenger side of the transmission, 2 14mm bolts and a 17mm to take the hose off, thats it. Worked like a charm for me and only cost $29.77. Hope this helps
S13FASTBACKSR
Car: '92 Fastback SR powered
bleeding it ftw..let us know if that doesnt solve the problem
donmada
thanx guys you havent let me down yet
