Clutch swapping
Discuss topics related to the VG and VE series engines.
slamdbusa
Car: 240sx, ex-ka-t, now sr
I bought a Z32 transmission, and the clutch is bad, Now I have an SR clutch and every thing matches up, but is there a concern using this SR clutch on the N/A Z32 transmission and flywheel?
I cannot find any related topics in the search section, so any advice will be appreciated.
Thanks,Matt
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
As long as the disk has the same dimensions (diameter and thickness) then it should be fine. You will want to compare the hub between the two to make sure one isn't set differently than the other. If they appear to match I don't see any reason why it wouldn't work. Splines in the hub are likely the same so that shouldn't be a problem.
One thing to consider the clamping force of the SR pressure plate. It may be less than the Z's if both are stock which could possibly keep the SR clutch from handling the higher torque it would see with the VG. Something else to consider.
Hope that helps.
slamdbusa
The only reason I ask is the SR clutch I have is the same as the one I have in my 380HP SR. I belive that it would hold up, but wanted to see if anyone else has done it.
mtcookson
1992 Iinfiniti Q45
and much much more
If its aftermarket it probably would hold up pretty well. I don't know of anyone off hand using that particular clutch but if the dimensions are the same I see no reason it wouldn't work.
tmorgan4
Car: 2000 Nissan Pathfinder
LUK lists specifications of their clutches on their website. Mainly diameter and input splines. Put in the two vehicles and see if you get interchangeable specs.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
what car is this clutch/trans in?
i am using a z32 n/a trans behind the vg30e in my m30, with a maxima flywheel, and exedy stage 2 clutch meant for a rwd sr20.
been holding up fine for about 2k miles so far.
Return to “VG30 / VE30 Forum”
