craigztoyz »
https://forums.nicoclub.com/craigztoyz-u86743.html
Thu Aug 19, 2010 7:40 pm
I have used the Centerforce II clutch on 3, Exedy 6 puck/lgtnd flywhl setup on a few, and the clutchmasters on a few. The stock unit has been used on a few customers cars, but they dont last to any real use, as they dont have enough clamping force to hold the torque of the VH.
What really matters is that you get a good unit with a strong clamping force to hold the torque, and dont double clutch it, you'll wear it out in no time. Use the SS line to keep the clutch pressure up, rubber has flex/expansion. Be sure to grease the shaft, use a bushing, roller are ok too.
Always use ARP bolts for clutch to flywheel, flywheel to crank.
