clutch stuck to the floor....help
boon240
Car: 1990 Nissan 240sx
here's the problem, my car have been leaking brake fluid for a week, i think my master cyclinder is f***, so i was waiting to get paid tommorrow and replace it. so yesterday when i went to start my car, steped on the clutch and the pedal just kinda went and stuck on the floor, so i have to manually pull it back, i check my clutch fluid and it was empty so i fill it up and still having the same problem. my friend said that i just need to bleed it, so heres my question, it is because of the master cyclinder, or i just need to bleed it, and if i do how do i do it?
sideways danny
Car: s13, CA18DET
sounds like a leaky slave cylinder
ricebike
2002 Quest
2005 Altima
in my case, the master cyl went 2 crap a few weeks after my slave cyl replacement.
outtacontrol240
touch the carpet under the the clutch pedal ....if it wet that means u need to replace it with this kit for the clutch master cylinder that u can by at kragen autozone only like 15 bucks
LayNLow240
Car: 92 240 coupe
i have the same problem. but im not leaking any fluids anywhere. i just assumed i need to bleed it more. which i havent done yet.
ricebike
2002 Quest
2005 Altima
Lay,
did you actually crawled under the car on the pass side & peel back the dust boot of the slave cylinder?
there's also a case where the master can develop an "internal leak"
