Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Aug 12, 2004 9:20 am
could be the slave cylinder. check both your MC and SC for leakage, and also check to see if the resevoir is empty. One other thing is when was the last time you changed the hydrolic fluid in your clutch line? After a while, it will start to get hydrogenated and lose its ability to resist compression.
What sounds like to me though is air in the system. A clutch pedal with no force working back on it will stay stuck to the floor. The spring doesn't bring it back, the pressure plate acting on the SC is what pushes the pedal back up.
