clutch stuck... :(
DriftGirl
Car: S13 - Soarer - Aristo
Got in the car. Clutch went to the floor.
Battery was dead, so I went to jump it.
Got back in the car and now the clutch pedal is stuck at the top and will not move
oh yeah, ACT 6puc clutch with ACT heavy duty pressure plate (unsprung)
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
try cracking the slave cyl bleeder open while someone applies pressure to the pedal. if the pedal moves its either your slave or something in the clutch, if the pedal dosent move its your master or something in the line.
rudy543us
Car: 89 240 SX
It is the heavy duty clutch and pressure plate,what the hell do you have that for?
You master or slave if not both are dead. figure out which one and then go to http://www.nicoclub.com/articles.php?id=251959this is under Tech pages / transmission/ clutch block removal it really helps when you install a heavy duty clutch and pressure plate.
Good luck
Ciao
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Does it look like your slave is extended all the way out?
