Clutch stuck hig
foress_89
Car: '93 240sx
Hey guys my car have been parked a while, and now well I can depress the clutch. It's like seized at it's highest I just can step on it... Now obviously something is seized but I was just wondering if this had even happened to any of you.
I'm just not sure where to start, anyone think it would be most likely the master the slave or the pedal assembly?
Modified by foress_89 at 9:42 AM 2/17/2010
kt
Car: 90 240sx
i would start with the linkages b4 checking the hydrolics
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Is the pedal stuck at it's highest point or is on the floor?
foress_89
Car: '93 240sx
at it's highest point, and I just went to check it, the pedal arms moves a littles bit but it won't go down... I'm probably going to have to take the hydraulics apart.
sx moneypit
1986 Toyota MR2
The throw out bearing could be seized up on the input shaft sleeve.
foress_89
Car: '93 240sx
ahhhh thanks for giving me yet another possibility. I'm pretty much taking everything out of the engine bay this spring anyway so whatever.
sx moneypit
1986 Toyota MR2
No problem brother,keep us posted!
