clutch stiffen up
jdm_240$x
Car: 1990 nissan 240sx
i have a 1990 240sx and it has the stock single cam ka24 and about 6 months ago i changed the slave cylinder and it did jus fine but i think my throw out bearing is goin out.so my question is would the throw out bearing causing my clutch to be stiff sumtimes??
scottydog
Car: 1992 240sx
When the to bearing goes out it starts to make noise when the clutch is depressed.
What do you mean exactly by stiffening up sometimes? Do you still have the damper box in the clutch hydraulics?
jdm_240$x
yea you can hear the throw out bearing and i knew that was goin out but sumthimes when i turn my car off the clutch stiffens up hard and i have to reach down and hit the clutch switch and turn the key and after the car is running i push in on the clutch and its back to normal??
jdm_240$x
bump
scottydog
Car: 1992 240sx
Your to bearing may be getting stuck on the input shaft. Time for at least a new bearing. New clutch maybe while you have it all apart.
jdm_240$x
ok thanks i was goin to replace everthing in the trann..
puerkone
Car: 1989 Nissan 240SX SE-R
I have an S14 transmission in my S13. I am using my S13 clutch line and slave cylinder. When I drive my car, as soon as I press the clutch pedal to shift gears, my pedal would not return. It only returns half way of what was pressed in. I already tried different clutch pedals and master cylinders and bled the line and it is still doing it. so what do you think is the problem? by the way I tried adjusting it from the pedal too.
scottydog
Car: 1992 240sx
Have you gotten rid of the damper valve/circuit? Sounds hydraulic. The damper is crap, gets gummed up and bleeding with it in the circuit is a PIA. There is a posting on how to remove, rebleed. I bet that will take care of your problem.
