Ty for help in advance! And sorry if I have typing errors using my itouch and it's a pita too type on sometimes!
That slipped my mind! That's probably your problem. It just means you're not fully disengaging when you press the clutch. Keep us posted on what you find!gumby74 wrote:you need to adjust the m/c again.
words of wisdom here..some info he posted you might want to consider again!..like your choice in fluids!..speedeast wrote:![]()
When in doubt bleed again. What I would do is start the process over from step one to ensure you cover all of your bases. Take the Clutch Master Cylinder out leaving the clutch line fastened high not to lose any fluid. Bench bleed the CMC, then reinstall it and bleed the whole system at the bleeder valve on the Slave Cylinder. It is definitely best to bleed it with a friend, but if you can find two, the process goes much faster. One on the clutch pedal, one on the bleeder valve (usually my position of choice), and one keeping the fluid level perfect. Just a heads up in case you didn't know, DOT 3 or 4 brake fluid is what you need, don't waste your time searching for something labeled clutch fluid.
Good luck.
