Aworkinprogress »
https://forums.nicoclub.com/aworkinprogress-u34485.html
Sat Feb 25, 2006 8:39 am
Sorry deadrodent about the dissagrements. not cool punning my name to discredit me though jt. Anyways i dont see how that pushrod (between pedal and master) would cuase your clutch not to engage. From what I understand hydrualic clutch systems are like plumbing, and well, if you push your pedal in 80% down the master will purge 80% of its fluid, and when you release the pedal all the way back up that 80% of the fluid wil return to the master. so logically to me it seems that this feature can only cuase a problem for clutch disengagement, not clutch engagment, but jt correct me if im wrong. I would like to hear it so i know better for future applications, and that would be more apreciated then a pun. (Also yes the clutch switch is for cruise control) Besides that, it does seem you narrowed a problem to the master cylinder but with the loose pushrod between the fork and slave it doesnt explain why the clutch is not already engaged. Maybe the fork is getting hung up.. Did you lightly grease the throw out bearing and the shaft when you installled the clutch? could be problem but check everything first before concluding to this. Note that if the pushrod between the slave and fork is loose your problem of clutch engagment is not before the slave. Are the flex hose, master and slave all new?
