240sxJay »
https://forums.nicoclub.com/240sxjay-u9537.html
Fri Aug 06, 2004 9:53 pm
Are you running NA or Turbo? If you are NA then go with the ACT HD Clutch Kit 6 Puck Disk. If your turbo I'd think of something else. Go with a fidanza flywheel again if your N/A ...even then a flywheel mod, I guess if your pumping around 200hp it's worth it, if not hold off for a bit and get other mods. Stillen is another flywheel however it is 200 bucks more than a fidanza, weight is the same (11 pounds)
B&M will work great with anything, actually there is not another shifter I think I'd rather use.. some people like the "c's" which i think is no longer being made and was created in japan, pilots suck, obx suck and haven't heard about megans yet, though the setup seems to be pretty close to OBX.
