Clutch Slipping??
phayzer422
Car: 1993 Nissan 240sx SE
I recently bought a 1993 Nissan 240sx. Within the past two months, I went over the 200k mile mark. When my clutch pedal went spongy, I bypassed the dampener box and bled the slave. Within the past week, my clutch seems to have started slipping BADLY. I can be in 5th gear going 75mph,running 3000rpm, start to go up a hill, rpm remains at 3000, speed drops drastically. Also, when I start from a stop, my car seems to have almost no get up and go, and it can take like 30 seconds before I can hit 30mph. The rpms just slide up and the speed does next to nothing. My car used to be soo zippy! Could it be that I need to bleed my clutch again?? I can shift gears fine!
**Car is at 204K miles, clutch is original Factory.
tl;dr: I'm pretty sure my clutch is slipping badly. Should getting the clutch replaced fix this?
(Thanks guys. I'm new here and appreciate ALL the help!!)
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Welcome! Sounds like slipping clutch to me. If you replace it it should be good to go. I would suggest a few maintenance things when you replace it:
1. Have the flywheel resurfaced, this will ensure a proper mating of the new clutch.
2. New throw-out bearing.
3. Replace the rear main engine oil seal. It is inevitable that about a month after you get the new clutch in the seal will go bad and oil-soak and ruin your new clutch.
Did I forget anything guys?
truckmtr240
Car: 91 240sx hatch
Also try adjusting the clutch travel under the dash above the pedal. Fixed my problem.
