mikalkouki »
https://forums.nicoclub.com/mikalkouki-u36365.html
Fri Mar 30, 2007 3:13 pm
so I'm getting ready to change my clutch and my buddy want's to go for a ride and see exactly what its doing. we came to the realization it doesn't seem so much like the clutch is slipping!!?? Under load it starts to free rev but only to about 5-6k and stays at that rpm but not putting much if any power to the wheels...... The smell also doesn't smell so much like burnt clutch, it smells more like raw brake fluid/clutch fluid. However the clutch continues to engage perfectly through every shift and the master cylinder is filled to the top. Also when it slips in and out under load it never jerks or has a feeling of catching and releasing, its all smoothe. I'm going to change the master cylinder and slave cylinder tomorrow and re-bleed the clutch. Also I'm going to put some washers behind the clutch pedal as I was advised to do, cuz I swapped in an s13 clutch pedal and master cylinder into a s14 auto chassis. Any input on what could cause this and how I could better diagnose the situation b4 I change the clutch is very much appreciated!!!!!
