I might try adjusting the pedal even further down. Idk if this is how it works, but it's my speculation. If the pedal is up too high then as everything gets warmed up there's some expansion and the pedal gets pressed against the top of it's travel and let's the clutch slip. I've had a couple of my cars do that before when adjusting the pedal.
Doesn't it totally slip, or just doesn't grab as hard as it use to? If it just doesn't have that "kick" it use to have then I would think nothing is wrong. Just the pads aren't as fresh as they use to be and don't clamp as hard. But you'd know a lot better than me how strange your car is feeling.
Personally I'd go with a Spec stage 3 in your situation
I've had several strong clutches and they feel normal to me now. They're easy for me to control and very responsive, lol. I can't stand really light clutches now. Anyways, idk if a stock clutch would hold that much power. A brand new KA clutch could probably hold it. Only $80, too.
I had one off a motor, but didn't like how the bolt holes lined up and feared balancing issues so I didn't use it. Then again, I finally got to try my 12lbs flywheel and it didn't have dowel pins. So I got the proper pins for it, but they didn't quite line up with the holes on the pressure plate after I enlarged them, so I slotted them to make it fit. Point being, I thought I'd have balancing issues with the minimal modification required to run a KA clutch, but did much more modification to the CA clutch I used to run a certain flywheel and all seemed fine.
I have an ACT stage 3 clutch with a sprung hub and I think it's an absolute joy to drive. But it's hard to gauge how you'll like something based on someone's opinion online. A stock KA clutch I think would hold the power, but it wouldn't bite like most aftermarket clutches would (something you'll want if you're power shifting or speed shifting).
