Luderacer14 »
https://forums.nicoclub.com/luderacer14-u24944.html
Tue Jul 12, 2005 4:24 pm
Ok guys, in my last post, I said my bearing shaft broke. When I took it apart today, it was'int the shaft, it was the flywheel. All the bolts were coming lose!!!! I remember reading a post about some guy that almost got his legs cut off by the flywheel, thank god i still got my legs. Anyways, now my clutch pedal feels really soft and when full boost kicks in at 3000, it starts slipping and it srings back very slowly. I'm not sure if it's the clutch or the tires. Sometimes you will see tire marks after 3rd gear when I feel the car floating. It's a ACt street disc. I'm curently running 10psi with downpipe. Anyone have the same problems? My clutch gripped great before running at 7 psi, before the flywheel incident. The clutch looked fine, could my pressure plate be jacked up?? It looks good too.
