Clutch slipping? or newb w/ stick?
NissanSupraGTR
Car: 1990 240sx SE hatchback
I don't know if the clutch is wearing in or slipping or just me sucking. Recently replaced by my mech w/ a stock version. The main problem's only when i start from a stop. Whenever i try to start quickly, the rpms dip then rise up again, making for not-so-quick starts....Also feels like its catching higher than before...Im relatively new to a stick (can drive round normally fine, problems seem to come up when i try to be speed racer) so it could be me...any advice?
LayNLow240
Car: 92 240 coupe
was it a brand new clutch? did you break it in without heating it up a lot?
NissanSupraGTR
LayNLow240 wrote:was it a brand new clutch? did you break it in without heating it up a lot?
Mechanic said it was valeo - i took it easy for about 300 miles - no redline, no burnouts, just normal driving.
adrianfromthecastle
Car: 1992 Nissan 240sx
clutch slipping is more of your rev's on gear going up, but your car going nowhere (while on gear and no foot on clutch pedal),
or almost like your driving on gear with your foot depressed on the clutch but not letting go of the clutch till like 2000 rpm
Car: 240sx
i have a feeling its just u sucking.....try reving up to about 3000rpm then letting off the clutch fairly quickly....should be a quick start.
drift donkey
Car: s13
you will know your clutch is slipping if you gun it and your RMPs shoot up, but you don't really gain any speed. It will feel like your car weak as hell. You might also need to adjust your clutch pedal.
NissanSupraGTR
2056515 wrote:i have a feeling its just u sucking.....try reving up to about 3000rpm then letting off the clutch fairly quickly....should be a quick start.
yeah - just tried that, and the car leaps - i honestly didnt think it could do that; gonna be practicin that a lot more
fulmore240
Car: 93 240sx ka24d
put it in third gear from a dead start....and if it stalls ur fine but if it moves then its slippin...try bleeding your slave cylinder first
NissanSupraGTR
fulmore240 wrote:put it in third gear from a dead start....and if it stalls ur fine but if it moves then its slippin...try bleeding your slave cylinder first
tried what you said, released the clutch normally and it stalled, but when i release it slowly the car begins to move...
bone_stock_240
Car: 1995 Infiniti Q45
Yeah, I have a feeling it is due to your sucking then. When I first started driving, I was pretty bad at times, and I thought it was the car. It was just me though. Now I am one of the best drivers in the world. True story.
