The_caveman »
https://forums.nicoclub.com/the-caveman-u189461.html
Sun Aug 28, 2011 8:13 pm
SO my clutch slips really badly...however its not due to a bad clutch...I replaced the clutch,springs and throwout bearing not but a few months ago.
The interesting part about it is that my slave cylinder pin was getting bound up.
the piston inside the slave would push all the way out until the piston would be literaly outside the slave itself and the whole assembly would bind up...me my friends and my dad assumed the clutch fork was bent, so my dad fabed up a extra long slave cylinder pin to make the clutch work, which it did it just slipped really badly
So that brings us to today,i finnaly separated the engine and transmisison.
Took my good clutch fork and compared the to the "bent" one I could only see maybe a mm diffrence between the too when both laid out on a flat surface.
I am already ordering a nismo pivot point,and have a new fork,throwout,springs,pilot bearing and clutch, however anyone got any ideas as to what is causing my problem i'm a little lost here.
