Nali »
https://forums.nicoclub.com/nali-u88675.html
Sun Jun 21, 2009 2:09 am
Heres a simple check for you.
While parked, pull the Handbrake > Put car in a high gear > Drop clutch.
If the engine keeps running then the clutch is wasted, if the car bucks and stops the clutch is gripping.
You can only do this for like a split second as the heat from a slipping clutch is like...
