yellow_jacket »
https://forums.nicoclub.com/yellow-jacket-u4236.html
Fri Mar 21, 2003 3:50 am
Possible, but kind of unlikely. Is anything dumping oil on the clutch? Rear main or valve cover? It usually takes a minute to heat a clutch up to the point that it will smoke and smell bad like you were describing. It almost sounds like you had been doing something else before you downshifted and hammered it.
If it isn't an oil soak problem, then the cluth may be getting worn out.
