Clutch slave upgrade
Doomed2Walk
Car: 2005 Subaru Impreza WRX STi WRBP on gold
I got an exedy stage ii clutch when I got my sr swap done and occasionally I'll hear the gear box grinding, so I am going to bleed the system and see if it corrects the problem, if it does not, should I upgrade the slave cylinder and any recommendations?
S13ChucKAT
Car: asd
I dont see any advantage of upgrading the slave cylandar.. if anything it would just be a new spring assembly for inside the slave. i think you might need to bleed your lines, and get rid of the diffuser box
skylndrftr
Car: 07 Nissan Versa S
2010 Ariel Atom (pending...)
does anyone know the sizing of the S13 slave cylinder? i can't seem to find it in the manual I have with mine
Doomed2Walk
It's not in the FSM? I don't remember any of the links but you could try searching for factory service manual or fsm and see if anything comes up.
