clutch, slave, master?
oki_bum
Car: SR Powered 1990 240SX
Well my problem is that i moved the clucth fork by hand (dont ask why) and it made a popping noise, now my clutch pedal has no pressure. When i push it in, it sinks to the floor and i have to manually pull it back up. So im asking for some advice on what to do? I REALLY REALLY REALLY don want to have to take the transmission off. If its as simple as replacing the clutch slave or master cylinder, then cool, if not please let me know.
Modified by oki_bum at 5:32 PM 8/7/2006
S13FASTBACKSR
Car: '92 Fastback SR powered
did you bleed your system yet?
oki_bum
When i bled the system several days ago (before i messed w/ the fork), I had started with some pressure. And when i finished i had full pressure. When i tried to bleed it today after i f***ed it up, i had no pressure to begin with. So yes i did try to bleed it, but i was doing it by myself so i couldnt pump the clutch and hold it in while playing w/ the bleeder screw. So do you thin that all i have to do is try bleeding it again? When i messed w/the clutch fork, i was worried that i popped it out.
S13FASTBACKSR
ya bro thats your problem..ok you tried to bleed it but you didnt bleed it correctly..how you did it had pretty much had no effect..bleed it with a buddy and you should be good to go
oki_bum
i lost all pressure when i played with the clutch fork. Can i loose pressure when i do that?
S13FASTBACKSR
what do you mean? do you mean can you lose pressure from playing with your clutch fork? well if you did then yes i guess you can lol..
oki_bum
lol...okay then, i guess i'll try to bleed it again tomorrow. I was just worried i popped the clutch fork out of its place and had to take the whole transmission off to fix it.
S13FASTBACKSR
no man i dont think thats the case i think it just wasnt bled right...let us know
