Clutch Slave Cylinder
Chris777
Car: 2000 Nissan Maxima SE
I ran my clutch slave cylinder reservoir dry. Do I need to bleed my system?
OwnerCS
Chris777 wrote:I ran my clutch slave cylinder reservoir dry. Do I need to bleed my system?
Is your clutch working ok now that you have fluid in the reservoir?
I had to bleed my clutch system when I changed fluid and then again later when I changed to a steel braided type hydraulic line.
Chris777
I haven't had a chance to put any in.. Just wondering if it was necessary
OwnerCS
Are you able to drive the vehicle?
Chris777
It drives, just no pressure when engaging clutch, sometimes is hard to change gears
Chris777
When I say is it necessary I mean to bleed the clutch system
OwnerCS
It sure sounds like it to me.. Have you seen the clutch bleed procedure in the Field Service Manual?
