wildacexxx »
https://forums.nicoclub.com/wildacexxx-u24543.html
Wed Mar 22, 2006 7:57 am
i guess i'll just use a stock on then, thanx. oh heres wat courtesy says about the nismo slave
When using with NISMO racing clutch kit, this product changes the heavy clutch pedal feeling to a lighter feeling.Bigger cylinder diameter (20.54mm) comparing to the standard one (19.05mm) enables you to control the clutch pedal much easier.Best matched with the NISMO racing clutch series.
